Message 21 of 43
Re: Games only lag during the day.
Is that Sky satellite TV or Internet?
If that is a Sky "puck" as they call it, for internet TV, they are greedy little things.  I have one and it hogs 5 -6 Mb/s to itself when it is on.  In standby it's not a problem.
Message 22 of 43
The sky box is the cause for the lag. The sky box is needed though for my mother’s work as she has it on whilst working. Is there any solution we could do and is there any reason why the sky box is causing only my ps5 to lag?
Message 23 of 43
The main cause is the one mini sky box in our back room. All the other ones do not cause the lag when they are plugged in. We have 2 mini sky Q boxes connected to the main one. These are all connected to the internet, with the main one being connected to the internet and the satellite.
Message 24 of 43
The Q's obsolete anyway.   Tap Sky up for a new one, perhaps?
Message 25 of 43
i could do, what’s the main issue here anyway? I have another sky box upstairs which is the same one. Would swapping these around possibly change anything
Message 26 of 43
I've no idea but I know the Q is regarded as old kit and one of them may have developed a problem.
If you are sure it is the Sky kit, you would be better posting on the Sky forum.  Chrisee, TimmyBGood, Caesarome, cookiemonsteruk & JimM1 are all good.  I'm sure one of them can advise.
Message 27 of 43
If you are using WiFi, Sky Q uses channel 36. Make sure you are using a different channel.
Message 28 of 43
100% it is the sky box as everytime i unplug it lag stops. I made a post in the Sky forum and i’ll see what they say.
Message 29 of 43
This is good to know, however like i said i use the TP link adapters on my PS5, would this still affect it though, and i know we’re using channel 36 so i’ll give this a go and let you know, thanks for your help.
Message 30 of 43
I did suggest changing channel some time ago.
