Message 1 of 4
Packet loss at minute intervals?
We're on a Fibre 250 plan (G.fast over a short-ish length of copper) and since yesterday we've been seeing periods of complete outage, but the rest of the time packet loss on the minute for about 4 seconds. I haven't completely ruled out other factors, but it does seem to an external issue, rather than being related to the internal network.
Has anyone else seen anything like this?
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Packet loss at minute intervals?
My line had been showing increasing packet loss recently until almost failing completely on Sunday. At that point there was horrendous noise on the line & sometimes no dial tone. Reported & repaired on Tuesday, so a quiet line test would be worth a try, especially if like me you don't use the landline.
Message 3 of 4
Hi @tobiasjs,
How are things with your connection? Did you try the quiet line test as suggested by @Anonymous?
If you're still having problems with your connection, post back.
Thanks,
Paddy
Message 4 of 4
As said line noise is the most likely cause. 17070 option 2 and best with corded phone. You may get a dull hum with cordless. The line should be silent between announcements.
Any noise (other than stated) should be reported as a noisy line fault, NOT broadband. Once the line is sorted you broadband should follow suit.
