Message 11 of 13
Re: Possible Home Essential Fibre 2 Speed Capped
@ngr49er Thanks for the update, changing the plan has appeared to have done the trick with the profile.
Neil
Message 12 of 13
It has now been all sorted, was put back on Home Essentials Fibre 2 yesterday.
The speeds remained the same, around 58mb download and 17mb upload.
It means that I was capped on Fibre 1 originally and now have Fibre 2 speeds for my distance from the cabinet.
Thank you for everyone's help on this thread.
Nigel
Message 13 of 13
I know this is an old and solved thread.
But just wanted to highlight how this case is exactly the same situation i'm in. Which im hopefully gonna resolve for the 2nd time tomorrow on Monday. And if they don't, il contact them every single day until they do!
https://community.bt.com/t5/Bills-Packages/Can-t-order-upgrade-online/td-p/2265300
My thread on the same issue ^
