Message 11 of 22
Re: Providers don't think I can get superfast broadband when Openreach says I can
 That would tally with what providers are saying but not with this, from Openreach results
Message 12 of 22
Ope reach just show that it is available to your address but as already posted your cabinet is full and you have a waiting list hence you cannot order FTTC and  FTTP is not available
Message 13 of 22
I see.  So available but not available.  Tricksy! But at least I know what's going on now so thanks both.
Message 14 of 22
The Openreach site just shows generic information, the checker, real time information updated weekly.
Message 15 of 22
In order for me to get superfast, would someone using that cabinet have to get superfast disconnected? (And why would anyone do that?)
Would the alternative be that Openreach build another/bigger cabinet?
Message 16 of 22
You ask why anyone would disconnected from FTTC ( Superfast ) , but you are moving into a property , for you to do that , someone moved out , as people move in and out of properties they cease and connect to FTTC , some may use a different network, or just use mobiles , so ‘waiting list’ today could easily become ‘available’ tomorrow….it’s even possible that the property you are moving into had FTTC but the previous occupant hasn’t advised their ISP yet  that they have moved out , so the Openreach equipment they were on isn’t yet showing as available but will soon.
Openreach do increase the capacity of cabinets if they see the commercial need , but with the onus on FTTP and not FTTC , expansion of FTTC probably isn’t going to make commercial sense
Message 17 of 22
Aha. So, its the ISP that takes up the cabinet space, as it were, rather than the property itself? Makes sense.
Do you know if there's a way of setting an alert so as to be notified when a cabinet space becomes available? Or is that the 'Register My Interest' button here?
Message 18 of 22
In the very unlikely situation that the cabinet is sub-equipped with plug in cards, it would be a simple matter to increase the capacity and Openreach would do so fairly quickly. However, in the far more likely scenario that an extra cabinet or extension to the cabinet is required to provide capacity, it just won't happen I'm afraid.
Message 19 of 22
As stated earlier, the concept of a waiting list is a misnomer, there is no alert system or register of interest.
Message 20 of 22
One glimmer of hope is the way in which home moves are handled. If a customer moves out of a property, the new owner doesn't automatically get the port, it is made available and the first to grab it gets it. Not good for people moving into a property with service hoping to take it over, but good for you without a service.
