Message 1 of 2
Re: Messy and badly finished full fibre installation
You're not alone bunny - I had my full fibre installed yesterday, apart from the shoddy/sketchy work (see photos) the engineer basically lied to me when I asked if he was going to remove the copper wire from the telegraph pole which is attached to my house and take away the old internal box etc. - he said that was for BT engineers to do and not Kelly (the subcontractors) - BT says the engineer should have taken away the old equipment.  Anyway, shocking install!!!
1 REPLY 1
Message 2 of 2
Hi Robbie - Thanks - I've had a look at the Openreach complaints section - doesn't look that promising, so I''ll also be taking up the issue on X/Twitter.
Best,
AXW
