Message 11 of 14
Re: Really poor broadband connection
@roco1970
Your current hub connection stats are actually better then your previously posted stats. Connection time less than 1 day are you having problems with router dropping connection or is it due to manual reset?
Message 12 of 14
Hi! I'm Charlie!
You may need to contact BT as a multitude of things could of happened:
If you have a copper cable (Not Full Fibre): The cable could of broke underground or something could be a problem with it, there could be a problem with your phone box, a cable cut in your street, etc.
If you have a full fibre box connecting to a WAN port on your box: The full fibre cables could of broke or a cable could of been cut in the street or it could not be connecting properly
You can get in touch with BT with the numbers below.
Cheers,
Charlie.
I do not work for BT, EE or BT Group
I'm a very knowledgeable person! Ask me about anything you'd like to know
Contact BT on 0800 800 150 or 150 from your BT Mobile Phone or Landline
Message 13 of 14
Hi It stays connected for a week at a time then disconnects. Not sure why this happens.
last Sunday nothing would load on my phone so I ran a speed test and the ping rate was through the roof again. I thought this issue was gone but no it’s back again sadly.
Message 14 of 14
@chfrlie
If you had checked the hub stats you can see that @roco1970  is on FTTC fibre to street cab and copper to home and has a good fibre 2 connection 64mb so there is no problem with cable and Certainly not damaged or cut
As FTTC there is no ONT or connection to the hub WAN port
Information from @roco1970 about hub connection  which I requested will be good start
