Message 1 of 4
Repeatedly having to reboot hub to resolve poor wifi performance
For the last 3 months I have been having intermittent upload speed dropping issues. This morning it was 0.36 mbs before rebooting and 4.24 mbs afterwards. When I reboot the hub it is ok for a couple of days and then does it again. I have done all the things bt suggested including moving the hub around. It makes no difference how near to it I am either. Bts final offer was that it is my neighbours microwave causing the problem! There is clearly something wrong but what can I do as no one seems prepared to listen? I am using a home hub 5 type b.
3 REPLIES 3
Message 2 of 4
Re: Repeatedly having to reboot hub to resolve poor wifi performance
Have you tried a wired connection when this happens to confirm it is a WiFi issue?
Message 3 of 4
Thanks. I haven’t tried but will when it next happens which might be in a couple of days.
Message 4 of 4
Hi @Hoopoo and welcome to our community.
Thanks for posting about your upload problem. Please follow @rbz5416 advice and get back to us with your findings. I'm sure we'll be able to help you.
Cheers
David
