Message 11 of 16
Re: Slow Download Speed, but fast Upload speed
Hi Daniel, Thank you. I've responded to the private message.
Message 12 of 16
Just a quick update.
After speaking to the mods, I have moved SVLAN which has resolved my issue.
Thanks for everyone involved in resolving this.
Message 13 of 16
Hi can you please elaborate? What do you mean you moved svlan?
I am getting much better upload speed to download speed at all times, even off peak, so I'd really appreciate some details on what to try. Many thanks
Message 14 of 16
You are replying to a 5 year old post!!
It means the mod had the OP's circuit moved to a different svlan in the exchange.
Message 15 of 16
Thanks for the swift reply.
My net infrastructure knowledge is amatuer at best but that sounds like something only the ISP can request. If so, I'll request the same.
Thanks again!
Message 16 of 16
They won't do it your request. It was something the previous mods were able to arrange it the new mods no longer have the necessary access.
You will need to report the fault to BT.
