Message 1 of 2
Slow speed
Our street was recently upgraded to Fibre and so we upgraded our pack to 73MB upload and 500MB guaranteed speed. It has been really slow and a tester showed speed was only 2 and 13 respectively. We looked at community and did a factory reset which has improved it to 71 and 164.
How do i get 500 Mps??? thank you
1 REPLY 1
Message 2 of 2
Re: Slow speed
The guaranteed speed is to your router connected by ethernet.  are you trying the speed tests on wifi which is not guranateed.
try running fast.com using ethernet connection
