Message 1 of 5
brodband droping
hi i have just joind bt but i think i have a line problem my hub keeps going solid blue works for a bit then flashes oringe when it flashes oringe i get very odd sounds on phone side even tho i have brodband without landline heres a vid of what its doing https://youtube.com/shorts/UiKYxqKOyXU
4 REPLIES 4
Message 2 of 5
Re: brodband droping
do you have FTTC or FTTP  assuming FTTC which master socket do you have?
Message 3 of 5
Fttc mate and its soket 5c mk4 faceplate I have also tryed in test soket with microfilter
Message 4 of 5
Not shore if it let you watch the vid with the noise I'm getting on phone when it try's to sync up I don't think it's normal but I don't know
Message 5 of 5
if you try quiet line test  - dial 17070 option 2 and should be silent with corded phone.  any noise need to be reported as a phone fault not broadband to 151 or 0800800151 from mobile
