Message 11 of 20
Re: Cancel mobile
@Arryz
Effectively, what it means is, you have to give 30 days notice of cancellation to BT. You cannot do that without calling them as previously advised. It’s probably designed that way to make your life as difficult as possible so that they can try and retain you. Call them and tell them you want to cancel, no ifs no buts.
Anonymous
Not applicable
Message 12 of 20
Re: Cancel mobile
Ok I give you two options,  one was PAC the other is STAC..this stands for
Srevice Termination Authorisation Code.
These systems were put in place to make switching and cancelling easier.
May I again suggest you at least try them
Message 13 of 20
Re: Cancel mobile
@Anonymous
With respect, you might be clutching straws suggesting the STAC option as I believe it can only be used when switching provider and you don’t want to keep your old number. I’m not so sure you can just request a STAC to terminate a contract completely.
If it were me, I’d probably just get a free SIM card and Port out the BT number to it thereby switching and closing the BT account. The old BT phone number then goes to a throwaway SIM that you either activate by putting a top up on it, or you do nothing with it and eventually it just expires.
Anonymous
Not applicable
Message 14 of 20
Re: Cancel mobile
My god Kimbo that's actually a really cunning plan...more cunning then a fox who's been appointed professor of cunning at Oxford University
Message 15 of 20
Re: Cancel mobile
@Anonymous
You're very nearly but not quite as sarcastic as me 😂
To be fair, I sim swap on mobiles frequently chasing really cheap monthly deals, so I get 10GB of data month with EU roaming and all that jazz for £1.30 a month for 6 months and then I just do it again. I probably never pay more than 20 quid a year to have a minium of 10gb a month because I'm so tight.
Anonymous
Not applicable
Message 16 of 20
Re: Cancel mobile
  • Sarcasm is the lowest form of wit, but the highest form of intelligence
Message 17 of 20
Re: Cancel mobile
@Arryz
If you decide to call BT in order to cancel your mobile contract, you do not need to enter into any dialogue about being retained as a customer.
Just inform the Customer Service Rep that you are calling to terminate your mobile contract and that you do not want a PAC or STAC. and that you are giving them the obligatory 30 days notice starting on the date you call.
Other than possibly giving you information regarding any termination fees if you are still in contract or being billed for any usage during the thirty day period that should be all there is to the call.
If they do try to retain your business just tell them that you are not interested.
Message 18 of 20
Re: Cancel mobile
@Anonymous
Well I'm not entirely sure that applies to me, I'm as thick as two bags of flour with a breeze block stuffed in the middle.
Anonymous
Not applicable
Message 19 of 20
Re: Cancel mobile
What happened to two short planks
Anonymous
Not applicable
Message 20 of 20
Re: Cancel mobile
If you do phone and speak to a representative make sure everything that's agreed/promised is confirmed in writing by email.
Sadly call centre staff say one thing and often do another
