Message 1 of 14
Mobile rip off
On holiday in Sheringham BT mobile have put me on maritime network which is classed as roaming costs a fortune.
Rang the helpline they thought I was on a cruise no help at all wanted to send EE Sims. Will have a huge bill this month
13 REPLIES 13
Message 2 of 14
Re: Mobile rip off
Turn off mobile roaming because you've connected to a passing ship from the sounds of it ..
Message 3 of 14
Re: Mobile rip off
No it's on all the time turned off roaming now but still charged £40 for 1 evening never even thought about it in Sheringham come every year never happened before we are a bit closer to the sea now
Message 4 of 14
Re: Mobile rip off
@Malk1 if it held it's connection, it's probably a ship or yacht at anchor somewhere just off the coast...
Message 5 of 14
Re: Mobile rip off
I see no ships only windmills
Message 6 of 14
Re: Mobile rip off
They don’t have to be in sight, while in Dover I kept connecting to France.
Message 7 of 14
Re: Mobile rip off
@Malk1 they don't need to be in sight. Weather/atmospheric conditions can cause radio signals to travel further than usual... You'll also have no buildings in between causing obstacles and obstructions..
Message 8 of 14
Re: Mobile rip off
Did you not get notification on mobile at outset advising the network your phone was connected to just like you  get when you go abroad?
Message 9 of 14
Re: Mobile rip off
It said you are on maritime didn't understand it at first thought it was a mistake never heard of maritime network before
Message 10 of 14
Re: Mobile rip off
So there is no rip off by BT just you didn't understand when your mobile advised you it was connecting to maritime and the higher call costs associated with connecting to maritime
