Message 11 of 18
Re: Settings Greyed out
We have exactly the same problem with a mobile on our account. Is there anything I can do to fix this myself or is it specifically an internal error which must be resolved by BT?
I'm trying to lessen the severity of the parental controls setting from "strict" to "light" so that socials work and also to let the phone be used abroad. These options are greyed out and the "try again in 30 mins" banner has been up for weeks.
Hope you can help! Thank you.
Message 12 of 18
Hi @BoldreMarie,
Thank you for posting and welcome to the Community. I'm sorry you haven't been able to manage your mobile service online. If you send me your details, I'll be able to get this investigated.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Message 13 of 18
I also have this same problem. Changed one of the settings for one of my family members phone number and it won't let me change anything again, the 30 minute message keeps popping up from the mobile app and on the laptop. It's been a week.
Message 14 of 18
I have this problem now , did you get this sorted and how ?
Message 15 of 18
I have this problem , did you get this sorted and how ?
Message 16 of 18
Hi @TrickyT2 and welcome.
Thanks for posting. I can get this looked into for you. Please check your inbox for my message and drop me over your details.
Cheers
David
Message 17 of 18
Hi, someone from BT contacted me and helped me sort it out.
I think it was a technical issue from what I remembered. They will sort it out for you once you reply to one of the messages they sent you
Message 18 of 18
Sorted it by moving to EE!
