Message 1 of 7
mobile phone setting
During recent power cuts my BT mobile phone reverts to Emergency calls only whilst I'm at home. This doesn't seem right and I assume it is a setting somewhere in the phone. Can anybody help?
6 REPLIES 6
Message 2 of 7
Re: mobile phone setting
Were you connecting using WiFi calling?  Do you have a very poor/non existent mobile signal?
Message 3 of 7
@PP54  If the power cut effected the EE mast then you may be connecting to a different mobile network which will only allow emergency calls.
Message 4 of 7
It might be worth taking your phone to an EE/BT shop if there is one near you and ask them to check the settings.
Message 5 of 7
Many thanks for the reply. Just checked and WiFi calling is enabled so could be the cause. Have disabled it and now await a power cut🙂
Being a technophobe don't really understand what WiFi calling is but must have switched it on some time.
Message 6 of 7
I would keep WiFi calling enabled but make sure you have your mobile provider  connection as priority connection and not WiFi calling
Message 7 of 7
Thank you Distinguished Sage, may I impose on your knowledge once more please? How do I prioritise the mobile provider (BT/EE) over wifi calling? Looked through settings and not obvious (to me). Recently at an event in a village hall and noticed the phone had emergency calls only, switched off wifi calling but made no difference.
