Message 1 of 8
Big Entertainment NOW content
Im having exact opposite problem, I can see all my now tv channels in EPG but cant access any of them Error code 6023 or 6017 permanently, can anyone help please ?
7 REPLIES 7
Message 2 of 8
Re: Big Entertainment NOW content
Hi @antb666,
Thank you for posting and welcome to the Community. I'm sorry if you've been experiencing issues with your BT TV.
If you take a look at - What do the BT TV error codes mean?
The IPC - 6023 indicates that there might be an issue with the Broadband side of your connection.
How is your BT TV box connected, is it hard wired to your hub?
What is the speed of your connection?
Have you tried restarting both the TV box and your Hub?
Thanks,
Paddy
Message 3 of 8
Hardwired to hub tried rebooting everything, I can see them through apps but not in epg
Message 4 of 8
On full fibre, 150 mb
Message 5 of 8
Hi @antb666 and thanks for trying that.
We'll need to take a closer look at this for you so I'll drop you a private message now so you can send over the details.
Cheers
David
Message 6 of 8
Can someone please help me
Message 7 of 8
Not had a message
Message 8 of 8
You should have that now @antb666 .
Cheers
David
