Message 1 of 3
BT ID activation
I've been trying to create and activate my BT ID but getting technical issues massage and to try again later. I ordered broadband today and have the account number. Therefore I can't login to follow my order. Thank you.
2 REPLIES 2
Message 2 of 3
Re: BT ID activation
It may be that the order has not been fully activated yet. I would try again in the morning and if you are still having issues post back.
Meanwhile make sure you have followed the steps as per this link.
What is a BT ID and how can I get one? | BT Help
Tags (1)
Message 3 of 3
Thanks, I'll try tomorrow.👍
