Message 1 of 5
Address error
BT still has an incorrect postal address for me.
None of the My BT optons will let me change it.
Any ideas?
4 REPLIES 4
Message 2 of 5
Re: Address error
you can try message now to billing and see if they can help or phone Cs 03301234150
https://www.bt.com/help/contact-bt/account-and-billing/broadband
Message 3 of 5
Re: Address error
Message 4 of 5
Re: Address error
Unfortunately @rogerwhit  these days if the CS units are not able to effect the change via the systems  they have access to , they don’t seem to be able to direct the issue/problem to offline teams that could own the issue. The default route then seems for the customer to raise a complaint whereby the problem should be tracked and addressed.
Message 5 of 5
Re: Address error
Resolved through Billing thank you
