Message 11 of 13
Re: BT ID and Account not linked
Still getting the same message
Please correct the highlighted errors and try again.Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and send the message when you are satisfied.
Message 12 of 13
Can you send me a new private message
Message 13 of 13
Thanks for sending over the details @33Briarwood .
I'm really sorry it took so long to get sorted but it turned out to be more complicated than the usual profile issues. I'm glad we got there in the end. Post back if you have any other issues and we'll be happy to help.
All the best
David
