Message 1 of 8
BT Openreach house name change
Hi, I believe I need BT to raise an ORDI request with Openreach to get my address/house name updated. My account is still under the old house name which was changed a number of years ago. The new house name and address appears as a separate entry in the broadband checker on BT’s and Openreach’s websites, so I need the data updated somehow. Can a moderator help with this please?
7 REPLIES 7
Message 2 of 8
Re: BT Openreach house name change
@cockerel
Welcome to this user forum for BT Retail phone and broadband customers.
Please can you confirm that you are a current BT Broadband customer?
Message 3 of 8
Yes I am a current broadband customer. When I moved into the house last year I used the old house name to place the order and everything went ok (somehow the router still got delivered to the right house). Royal Mail have the correct address it’s just that things don’t quite match up on the Openreach side. I’d like to get this sorted in case I need to move providers in the future or just for potential future equipment delivery from BT. Thanks!
Message 4 of 8
I will ask a moderator to help.
Message 5 of 8
Hi @cockerel,
I can get this looked into for you and hopefully get everything sorted.
I've sent you a private message with some details that I'll need. When you reply back to it, make sure you include your address as listed with the Royal Mail so I can make sure both our records and then Openreach records are updated.
DanielS
Message 6 of 8
Thanks for sending over the details @cockerel .
I've updated your billing address and sent the Ordi request off for you.
Cheers
David
Message 7 of 8
Hello
I have a similar problem can i get some help please
Message 8 of 8
Hi I have a similar problem
can you please ask a moderator to help me
