Message 1 of 3
BT full fibre 900mbps activation stuck 'exception'
My full fibre 900mbps broadband is stuck at the activation stage. I have called CS thrice and each time  a different advisor has different things to say. Totally fed up. I run a business from home and already had to cancel a client.
The activation date was yesterday and CS said it will be done by midnight. Nothing happened and when I called this morning and again this evening I am now being told there is an 'exception' on the line take over from Zen fibre. Not sure what that means but I am stuck with a dud router with no connection having to purchase a dongle to get by which is no way sufficient for my needs.
I am seriously having doubts about continuing with BT.
Is there any way I can escalate as every day passes, I lose business.
2 REPLIES 2
Message 2 of 3
Re: BT full fibre 900mbps activation stuck 'exception'
@braj_chan
Welcome to this user forum for BT Retail phone and broadband customers.
Are you a business user, as the BT Retail service cannot be used for business?
Business users have their own forum.
https://business.forums.bt.com/
Message 3 of 3
BT T&C do not allow you to run your business on a residential line and you need a business connection
