Message 1 of 9
Bill, £2.51 charge for Voice on mobile section of current bill
Bill, £2.51 charge for Voice on mobile section of current bill,
any ideas why?
we have mobiles only, we have a landline but no phone plugged in for a couple of years
8 REPLIES 8
Message 2 of 9
Re: Bill, £2.51 charge for Voice on mobile section of current bill
Possible causes of a charge on mobile bill - making a call(s) toanumber that is not included in free calls or sending mms text which are also not free and easily done or simply an error on BT part
Message 3 of 9
I have been getting scam calls in oriental languages going to my voicemail, listening to them then deleting them and blocking. Could it be this? if so how do I stop it?
Message 4 of 9
Hi @rasta
Receiving incoming calls are not chargeable, unless you're abroad at the time.
What does it show on the itemisation part of the bill next to the £2.51 charge?
You can view your bill and breakdown online.
Ali
Message 5 of 9
Message 6 of 9
According to your bill you made a call to a number which was not part of your free calls package which resulted in cost of £2.51
Message 7 of 9
If that was the case it would show the number I called?
Think I have just realised what I did, called a friend in Portugal 🇵🇹 😳
Message 8 of 9
Looks like you have found the cause of the charge on your bill
Message 9 of 9
Thanks for getting back to us with the details @rasta
Glad you managed to get to the bottom of the call charges!
Ali
