Message 2 of 4
Billing
Why can’t I view my bills or billing history?
3 REPLIES 3
Anonymous
Not applicable
Message 3 of 4
Re: Billing
 Make sure your customer account number matches your log in details
Message 4 of 4
Re: Billing
Hi @MatwellMog
If you are able to login but not seeing any bill details, it is worth checking that it is the account number that is linked as @Anonymous mentioned.
If it isn't, and you aren't able to add the correct account, or if it is the correct one, contact our Account & Billing guides who can help to get it working as it should be.
Michael
