Message 1 of 7
Broadband Cancellation
Hi.  I have a 2021 contract which ended 2023.  I'm changing service provider.  Does anyone know what equipment I'll need to return to BT and where I find its returns process?  I assume the router, TV box get returned but the extenders and TV aerial remain with me?  Any help gratefully received.  Thanks.
6 REPLIES 6
Message 2 of 7
Re: Broadband Cancellation
@GD2021
Welcome to this user forum for BT Residential phone and broadband customers.
You will be informed by BT, what needs to be returned, once your service is ceased.
What do you mean by extenders?
Message 3 of 7
Thanks Keith.  I'll await their returns email.  The extenders look like two electrical plugs which plug into your normal house sockets.  My router sits next to the fibre connection in a cupboard under the stairs.  My TV is in a room several metres away.  I connect the router to plug/socket 1 and then then TV to plug/socket 2 so I have a wired connection to the TV which leaves the Wi-fi free for other devices.  I'm pretty sure I purchased them and didn't rent them hence why I think they stay.
Message 4 of 7
Hi @GD2021 and thanks for posting.
You'll automatically receive a returns bag to send back any equipment. If you've purchased any it's yours to keep.
Cheers
David
Message 5 of 7
Fine, I was just checking that the extenders were not the BT Complete Wi-Fi discs, as they have to be returned.
Your new provider should inform BT that they are taking over your service, provided that your new provider used the Openreach network. If not, then you would need to inform BT yourself.
Message 6 of 7
Thanks David.
Message 7 of 7
New provider is on the case with them and BT both saying new service should be live 21/06/24. Fingers crossed.
