Message 1 of 7
Broadband Package
I have a broadband package, broadband and calls anytime. Fibre with halo 1. I pay £78.89 a month. Is it a fair price to pay?
6 REPLIES 6
Message 2 of 7
Re: Broadband Package
What speed broadband and inside or outside a minimum term ?
You can always compare what you pay to what a new customer would pay for the same products , but if ( as an example ) someone allowed their minimum term to expire and remained on that , although it affords a greater degree of flexibility, in that they can switch without any concern about early termination charges , invariably it comes with a financial penalty of paying more than necessary
…anytime calls ‘list’ price is £18 , so if you are paying around £50 for the broadband element, it’s a lot for 40Mb , but isn’t outrageous for 500 or 900Mb
Message 3 of 7
@Laxman3_ £79.89 is dear for broadband and phone. If you are on FTTC.
If you are on FTTP then is still dear but not by much.
I would look at changing your call package unless you really need anytime calls for your landline.
BT/EE are one of the dearest when it comes to call packages for landline. Virgin are not much better.
Message 4 of 7
Thanks for your prompt reply. Yes I would like to opt out of anytime call.
Message 5 of 7
as anytime calling is an add-on you should be able to opt out and go to PAYG.  however calling costs are expensive and if you use your landline to make calls then I would do some checking your previous calls before removing anytime calls
try using message now in billing if you decide that better without anytime calls  https://www.bt.com/help/contact-bt/account-and-billing/broadband
Message 6 of 7
Thanks everyone for your prompt response. Greatly appreciated. I am new on this platform, hence struggling a little bit. Please excuse me if any shortfall on my part.
Thanks again.
Message 7 of 7
For reference my Fibre 500 Halo 3 with PAYG calls is £44
