Message 1 of 7
Cancelling a line
I have tried four times to cancel my mum’s second line but without success. Now on line for over an hour waiting to speak to “the only department” that is able to cancel the line. Is this deliberate by BT?
6 REPLIES 6
Message 2 of 7
Re: Cancelling a line
as you are not the account holder do you have POA which allows you act for your mother and cancel line
Message 3 of 7
Am on the line now with my elderly ill Mum. Over an hour having to listen to loud music. No reply from the BT team.
Message 4 of 7
Thanks for your reply though.
Message 5 of 7
Now on phone for 1 hour 20 minutes. Does anyone from BT read these posts?
Message 6 of 7
My last post  - and just for the benefit of others. BT seem to have a tactic when you try to cancel a line of saying “it’s another department, Iwill out you through” and then you wait for over an hour and no one picks up. It seems a deliberate ploy to prevent customers from cancelling lines.
