Message 1 of 3
Cannot add an address manually because the computer generated one is incorrect
I cannot log my address manually on my account because the computer generated one is incorrect. Any suggestions apart from going to BT Help because they don't give an option on their phone choices
2 REPLIES 2
Message 2 of 3
Re: Cannot add an address manually because the computer generated one is incorrect
You should call BT Billing on 0330.1234.150
Message 3 of 3
Thank you for your suggestion
