Message 1 of 5
Deleting old accounts
I've just registered & seen that I have 5 accounts which is causing some confusion - I don't need! Please help as I'd like the 4 obsolete ones deleting. Thanks
4 REPLIES 4
Message 2 of 5
Re: Deleting old accounts
What accounts are you referring to. Is it broadband account, forum accounts, email accounts or something else?
Message 3 of 5
I think they must be old email or broadband - all are account numbers. I can give them to you if need them. Thanks.
Message 4 of 5
Hi @Ladybeetle,
I can have my team take a look into this for you.
I've sent you a private message with some details that I will need.
Thank you
DanielS
Message 5 of 5
Thanks for sending over the details @Ladybeetle
I'm glad I was able to get this sorted for you.
Cheers
David
