Message 1 of 6
Full Fibre upgrade order not closed
I had full fibre fitted on the 17th of the November,  However the order still shows as open.
5 REPLIES 5
Message 2 of 6
Re: Full Fibre upgrade order not closed
The order still hasn't moved to complete.
How long is it meant to take?
Message 3 of 6
Hi @verkosh, sorry you're still waiting for your order to complete.
The Full Fibre has been installed and is working I assume?
Did you change over to Digital Voice and if so is this working?
Cheers
John
Message 4 of 6
Hi John @JohnC2
Yes the full fibre was installed and is working fine.
We were changed over to digital voice and everythings working with that as well
Message 5 of 6
Hi Verkosh, thanks for confirming that for me. I'll sent you a Private Message so you you can get in touch with the Mod team and we'll get the order closed off.
We're very busy at the moment so it will take a few days to get to the case.
Cheers
John
Message 6 of 6
Hi Christopher,
Thank you for sending in your details. I'm Paddy one of the Guides and Moderators here on the Community. I'm sorry there was a delay in that order completion. I've checked that order and it's now showing as completed.
I've gone ahead and closed the case I have but if you need anything else or have any questions, please get back to me.
Thanks,
Paddy
