Message 1 of 3
Having trouble checking if virtual rewards card has been requested
Hi.  I recenty took out a new install of BT Fibre.  I think I have requested to obtain my £100 Virtual rewards card but cannot see any reference to it when I login to MyBT.  I emailed the company purecard.com but they dont appear to have receive the request from BT for this. Can you help ?
I think part of the issue is that I have two separate account Id's with BT on the same BT id.
Regards Paul
2 REPLIES 2
Message 2 of 3
Re: Having trouble checking if virtual rewards card has been requested
Hi @pjmeehan
Welcome to the BT Community and thank you for posting.
I am sorry for the problems claiming for your reward card.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 3 of 3
Hi @pjmeehan
Thanks for sending us your details.
Glad I could get this resolved for you.
Cheers
Stuart
