Message 1 of 3
How do I remove an old account from MyBT?
How do I remove an old account from MyBT.
I've seen this question asked many times, but the resolution doesn't appear in this forum.
At the moment, I can't activate Discovery+ as the MyBT login defaults to the old account at login, which has no products associated with it?
2 REPLIES 2
Message 2 of 3
Re: How do I remove an old account from MyBT?
Hi @karhar,
Thanks for taking the time to join our Community.
To remove an account you will need someone from BT to do it. I'm a moderator for BT so I'll arrange to get this removed for you.
I'm sending you a private message with some details that I'll need. Please note, it may take us a few days before we can currently get back to you.
Thank you
DanielS
Message 3 of 3
Hi @karhar,
Thanks for taking the time to speak with me today.
To confirm, I have removed that old account for you which should allow you to activate your Discovery+ with your current active account.
Take care and have a great day. If you need anything, please come back to me.
DanielS
