Message 1 of 6
Joining BT - Activation Date
Hi, I'm looking to sign up to Fibre 2 which is part copper/part fibre.
I want to time this with my move date, so am I best to order 14 days before I need it up and running?
Are you able to choose/change the activation date when ordering?
5 REPLIES 5
Message 2 of 6
Hard Credit Check without processed order
Hi, I started ordering BT Fibre as I wanted to know if you could select the activation date. I didn't proceed with the order, but I now have a hard credit check on my credit report.
I received an email afterwards to 'complete your order' which just takes you to the BT website to then place a new order, so will they credit check me a second time when I come to actually order?
How would I get the credit check removed from my report?
Message 3 of 6
Re: Joining BT - Activation Date
Hi @himonster
Welcome to the Community
Great to hear you're looking to take up Broadband with us.
It would be best to give our Customer sales team a call who will be able to find your pre-order request and complete it.
They will be able discuss engineer installation dates too.
Ali
Message 4 of 6
Have you checked what is available at your new home. If not then enter your address and post results including all the notes. It may be that you are in a FTTP area
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
Message 5 of 6
I can't post results due to unable to copy and paste or add screenshots here
Message 6 of 6
High
Low
High
Low
VDSL
80 73.2 20 19 66.2
Unavailable Ava
Range A (Clean)
VDSL
80
68.2 20 19 60
Unavailable
Ava
Range B (Impacted)
G.fast Range A (Clean)
Unavailable
G.fast Range B (Impacted)
Unavailable
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate (Mbps)
Downstream Range (Mbps)
Availability Date
FTTP Install Process
FTTP on Demand
330
50
Available
Other Offerings
VDSL Multicast
Availability Date
Available
Exchange Product Restrictions
Status
FTTP Priority Exchange
N
WLR Withdrawal
Y
SOADSL Restriction
N
FTTP is not available.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services, the stable line rate will be determined during the first 10 days of service usage.
