Message 1 of 4
Multiple accounts Issue on MyBT WebPage
Good Evening
MyBT WebPage contains references to both my current and 2 old BT Accounts.  When I log in it defaults to an old (closed) account.  How can I change this so that it defaults to my current active account?
Regards
Sean
3 REPLIES 3
Message 2 of 4
Re: Multiple accounts Issue on MyBT WebPage
Hi @sean_od1 I've sent you a private message so you can get in touch with your details.
Neil
Message 3 of 4
Hi @sean_od1, thanks for getting in touch. I can see that you've set up the BTID again now after I deleted it and the old account is no longer linked to your BTID.
Cheers
John
Message 4 of 4
Hi John
Yes..it's all looking good now.
Thanks for your help
Regards
Sean
