Message 1 of 9
No Smart Hub 2 with upgrade?
Hi. Just upgraded BT broadband and the deal offered showed the Smart Hub 2 as the device included, but BT say my order is complete and no new device has been sent. I have an old hub from about 5 years ago so was expecting with my upgrade I would be upgrading. Seems very misleading…
8 REPLIES 8
Message 2 of 9
Re: No Smart Hub 2 with upgrade?
This has been raised a few times ion the forum and you would only get a new hub if your existing hub was not sufficient for your package
Message 3 of 9
If your present BT hub works with your upgraded service you would not automatically be supplied with a Smarthub 2 unless your telephone service is being migrated to BT Digital Voice, which needs the Smart Hub 2.
Message 4 of 9
Why do you want a new hub? New isn't always better.
Message 5 of 9
It seemed to me that they were ‘selling’ the Smart Hub as their best, most powerful hub yet, so seemingly it would be better than what I’ve got. I was tempted to switch providers as I found the service wasn’t great, but instead thought ‘upgrade’ might just be what’s needed as I’ve been on the same deal and kit for a while and perhaps it’s outdated and slow.
Message 6 of 9
If you were changed to digital voice when you upgraded then you would have needed a SH2 unless you already had a SH2.  The days of free hubs when your renew your package are long gone
Message 7 of 9
Don't believe all the marketing hype you read.
Message 8 of 9
Thought all phone lines was moving to digital in the next 2 or 3 years.
So you would think the likes of BT would now offer their new BT Smart Hub 2 as standard for anyone on FTTC renewing or joining BT.
I know you have to have the new BT Smart Hub 2 if you move to FTTP.
Yes  if you cant get FTTC then BT should still offer the BT Smart Hub(BT Hub 6).
I using the BT Smart Hub(Home Hub 6) and have been since I got upgraded from the Home Hub 4 when I renewed my contract just under 2 years ago. Wifi is still not  always great in the house but it is an improvement compared to the Home Hub 4 that I was using.
Message 9 of 9
Hi @CMV43,
I am sorry for any confusion for when you changed your package.
I'd like to take a look at your order for you and see what you were promised.
I'm sending you a private message where you can reply back to me on.
DanielS
