Message 11 of 11
Re: Openreach keeps on canceling line installation with no explanation
You could also look at 5G mobile broadband with NEW EE as an alternative with FTTP like speeds, depending on location can be between 145mbps and 600mbps this is determined by how close to the mast you are or if you have a 5G booster on the outside of your property, how good the coverage is, etc etc you can check the coverage HERE or check HERE for availability.
Hope this helps! 🙂 If you like my reply and
want to say thanks for the helpful answer
then please click on the Kudos on left hand
side 😉 also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 😄
