Message 1 of 2
Re: How do I remove an old Account from MyBT
Hi @JohnC2 i also have a similar problem regarding an old account, any help would be much appreciated.
1 REPLY 1
Message 2 of 2
Hi @Addoughty The quickest way of fixing this is to set up another BTID with an email address that has not been used as a BTID before and it will work ok.
If you don't have another email address you can use I've sent you a Private Message so you can get in touch with the Mod team and we'll raise the request to get the current BTID fixed. This can take a week or more to be completed currently.
Cheers
John
