Message 1 of 3
Remove Closed Account from My BT
Hi,
I have three accounts showing within my My BT, two of which were closed a few years ago.
I am wanting to remove these two closed accounts from My BT, so that only the one active one shows, but I can only find an option to add an account.
Hoping one of the Mods may be able to help with removing. Seems to be a common question on the boards.
Cheers.
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Remove Closed Account from My BT
Hi, @nrae84 welcome to the community and thanks for posting, yes that's something we can help you with. I'll send you a private message so you can send over your details.
Neil
Message 3 of 3
Hi @nrae84, thanks for checking and replying to my PM to confirm the old accounts have now been removed.
Cheers
John
