Message 1 of 5
Remove an old account from MyBT
Hi
I have an old account from several years ago linked to MyBT. Please can you tell me how to remove it. I've tried phoning customer services but get stuck in a loop of "press this, press that" and can't actually find a way to speak to anyone.
I tried the chat feature, was on hold for ages and gave up. I didn't even know if I'd chosen the correct option.
Is there an easy way to resolve this?
Thanks.
4 REPLIES 4
Message 2 of 5
Re: Remove an old account from my BT id
Hi @Robbie1964 and thanks for posting.
Sorry you're having trouble getting the old account removed. I can help. Check your inbox for my message and drop me over the details. Just a heads up, we're really busy at present so its taking longer than usual to reply but once you submit the details we'll get to you in turn.
Cheers
David
Message 3 of 5
Thanks for the reply David. I've replied to your PM.
Message 4 of 5
Hi @Robbie1964
Thanks for taking my calls and discussing this with me.
Glad I was able to get this resolved for you, by getting a new BT ID and the old one removed.
Cheers
Stuart
Message 5 of 5
Thanks for your help Stuart, it's most appreciated.
