Message 1 of 3
Rewards card
When will I receive my rewards card. The email just says claimed and has no other information
2 REPLIES 2
Message 2 of 3
Re: Rewards card
Hi @Kimmyt,
You should receive the card within 30 days of claiming it.
Take a look here BT Reward Card to find out what to do if you've waited longer than that.
Let me know if that helps you, please.
Thank you
DanielS
Message 3 of 3
Re: Rewards card
Ok thanks for your help
