Message 11 of 12
Re: Switched from BT. New provider didn't inform them. Who is responsible for the bill?
I have been with BT and the BT Group for many years and I would still be with them if they could offer me FTP.
I have hung on and on for over 2 years now waiting for FTP to come and they keep promising but they have not delivered.
Even now, they are offering full rate fibre at 300Mbps but not until 2027.
My new provider has given me FTP at 1000/1000Mbps for less than I was paying BT for just 80/20Mbps and much less than BT is offering the 300Mbps service. Plus it is a fixed price, no annual increase for the term of the contact.
I'm not knocking BT, I have been happy with them for a long time and still happy with them, but they are not able to provide Fibre To Premises yet.
Message 12 of 12
Your Alt Net ISP is correct in one way , a delay in provision does delay the cessation of the old service …basically it’s only once the provision is confirmed as in and working (using OTS) that the OK given is to the old provider , BT in your case , to cease the old service and raise the final bill , this is to account for delay in provision so the user isn’t left with no service ( that’s how OTS is supposed to work they basically just manage the messages between the providers ) , it’s arguably the case that the Alt Net didn’t confirm the new service in and working immediately , it was only when you called them they did the necessary action ,they then via OTS sent the OK ‘ we have control of the customer’ to BT , and that’s why the BT communication turned up  soon after that .
This does mean though that the date your Alt Net actually sent the message via OTS to BT to turn off your BT service is the date you are liable for and your final BT bill will be up-to this date ,  ….presumably you never bothered with a phone service with your ISP using the Alt Net , if BT take a little longer to actually switch off your phone number that’s up-to BT , it’s their number , not yours , but if your final BT bill date isn’t the first day your Alt Net was working , it’s the Alt Net  you need to challenge about that , that’s  if it’s worth the hassle of trying to get them to credit your bill for what will likely be a relatively small sum , it’s also possible the Alt Net bill won’t start until the 25th Sept even though it was the 17th when the service was installed,
