Message 1 of 10
Weird message from BT
I am getting a strange message when logging in to BT (looking at latest bill) BT to switch accounts 2.jpg
 There isn't a purple arrow with drop downs. The appearance of the above stops me from doing anything else but logging out.
David
9 REPLIES 9
Message 2 of 10
Re: Weird message from BT
It is just a drop down from BT that allows you to switch BT accounts in order to check them should you have more than one BT account.
Message 3 of 10
I cannot do anything else but log out???
Message 4 of 10
Did you click on the message "OK,got it"
Message 5 of 10
No - I have heard of 'click bait'
Message 6 of 10
@Davidold80
Post deleted
Message 7 of 10
Perhaps I should be more clear.
It occurs when I visit (log-in) to view my latest bill.
Message 8 of 10
@Davidold80  You were clear, I’m the idiot that read your post incorrectly hence why I deleted it 😏
Message 9 of 10
Yeah, I get that occasionally.  It's just BT trying to be clever.  There isn't a purple arrow because you only have the one account.  Just click "Got it!" and move on.
Message 10 of 10
You are right. I can now verify my bill
Thank you
David
