Message 1 of 3
Wi-fi Calling
If I use Wi-Fi calling to make an outside UK call, like to Japan, will it incur any roaming voice call or roaming data charge?
2 REPLIES 2
Message 2 of 3
Re: Wi-fi Calling
It will incur your normal call charges whatever they are. You will be using your own WiFi, why would there be data roaming charges.
Message 3 of 3
Re: Wi-fi Calling
Hi @cklai welcome to the community and thanks for posting. Calls to Japan from your BT mobile are charged at £1.55p/min. As @licquorice mentioned you will incur your normal charges regardless of using wifi calling or not.
Neil
