Message 1 of 5
removing old accounts
Hi @Kielbasa ,
Are you having problems with old accounts on your BTiD?
Cheers
David
4 REPLIES 4
Message 2 of 5
Re: removing old accounts
Hi, can you remove my old BTiDs connected to MyBT? Can you send me private message so I can reply with old BTiD numbers?
Message 3 of 5
Sure thing @Kielbasa . Check your inbox for my message and drop me over a reply.
Cheers
David
Message 4 of 5
Hi @Kielbasa, thanks for your PM to confirm all is working ok now after setting up the BTID again.
Cheers
John
Message 5 of 5
Hi @paulsmith247,
Thank you for posting. If you send me your details, I'll be able to remove that old BT ID.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
