Message 11 of 22
Re: Apps unavailable
I think it would be best to have a chat with our technical guides @Annie44
They'll be able to access your account and have a check over everything including the box, the connection and the extenders to get to the bottom of what is happening.
Michael
Message 12 of 22
Thank you for your advice. Having spoken with the online team they think my extenders have developed a fault and are sending a new pair.
Message 13 of 22
Thanks for the update @Annie44
Please keep me posted with how it goes when the replacement ones have arrived.
Michael
Message 14 of 22
Update. BT emailed me today and asked me to call as there is a problem with my order. They advised extenders aren’t made anymore and the only way to fix my problem is to upgrade to EE Pro box. I am at a loss what to do now. I feel so let down
Message 15 of 22
I’m still in shock at the conversation when it’s a lie. Extenders are for sale. I remarked that to the person I spoke to and he said maybe buying them is the best option. I suppose that’s what I will have to do but I find the whole thing really upsetting. Only ever been a BT customer so to be treated so flippantly is crushing.
Message 16 of 22
Hi @Annie44
I'm sorry that this has been so upsetting for you. It sounds like the adapters aren't in stock as replacements anymore. Hopefully, once you've bought those adapters, it solves the problem.
Please let us know how you get on.
Chris
Message 17 of 22
New plugs have arrived, I now get solid lights on both power and Ethernet, but not one on data. Apps still unavailable, error code changed to YVM104. Box doesn’t detect internet. Any idea what I should do next?
Message 18 of 22
Thanks for coming back, @Annie44
Which adapters do you have? Have you tried restarting all of your devices (TV box, router and adapters)?
Chris
Message 19 of 22
I have BT Broadband Extender Flex 500. I have restarted everything more than. In different orders, one at a time, altogether! The data light does not light on the new plugs either, but the other two do. Apps unavailable still. Could an engineer be needed to look at the cabinet or something else?
Message 20 of 22
I think the best thing to do is speak with our technical support team again, @Annie44.
Hopefully they can help you get all set up with the adapters, and that in turn helps with the TV issue.
Keep us posted on what happens.
Chris
