Message 1 of 11
BT App not showing repositories
My BT Cloud has 5 repositories under All My Files. 4 of these are listed as Desktop and 1 as Sync. I want to download everything (200GB) via the BT Cloud App but only the Sync folder is showing in the App.
I have now tried on 2 different PCs and same on both. How can I resolve this please, as downloading from the Cloud itself is totally painful because of the limits of the folder structure and number of files that can be downloaded in one go.
Any help very gratefully received
10 REPLIES 10
Message 2 of 11
Re: BT App not showing repositories
have you read this post as it has helpful answers which may help you
https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/BT-Cloud-is-closing/td-p/2394468
Message 3 of 11
Yep no help!
Message 4 of 11
Hi @westmmark
Are you using the BT Cloud desktop app to try to download all your files?
There is some steps and information on our Download your files from BT Cloud help page to get you through.
Let me know how you get on.
Michael
Message 5 of 11
Michael
Yes I am using the Desktop app. I have tried it on 2 PCS (Win 10 and Win 11) and have uninstalled and reinstalled (app not running at all now on Win 11, which appears to be a frequent experience for many). The only files I can get are those in the repository marked SYNC, the other 4 marked DESKTOP do not download and are not visible to select in the app
Message 6 of 11
There have been some updates to the app today, @westmmark
Could you try uninstalling and re-installing again please?
Let us know if it's working any better.
Chris
Message 7 of 11
So this morning I have uninstalled the previous desktop app version and installed the latest attempt on Win 11. It launched (but the  icon is only showing in the system tray and a BT folder or icon is not in the start menu for some reason). It didn't automatically ask for sign-in to Cloud so I used Manage Account in the app which opened a browser tab with the following and so we are no further forward!! :
Error 500--Internal Server Error
From RFC 2068 Hypertext Transfer Protocol -- HTTP/1.1:
10.5.1 500 Internal Server Error
The server encountered an unexpected condition which prevented it from fulfilling the request.
Message 8 of 11
Thanks for giving that a try @westmmark.
I've sent you over a private message so we can grab a few more details on everything that's been happening here.
Peter
Message 9 of 11
Hi Peter
I have 3 repositories, 2 are Sync and the 3rd is Type Desktop
In the Repository type Desktop I can down load folders of under 10MB using the Web based BT Cloud but larger folders only down load the sub structure with each lower level folder empty. I have no memory issue on the laptop that would prevent this from downloading
Can you please help as I need to get this Repository copied before the end of the month and it is 400GB
Alastair
Message 10 of 11
Good afternoon @muskyjohnston, welcome back to the BT Community!
Have you tried downloading the desktop app for BT Cloud and restoring your files through here?
This has been updated really recently so will definitely be the best way to help get these files moved over.
Peter
