Message 1 of 2
BT App
I have recently installed the BT app on my phone and have been checking wifi speed.  Sitting 6 feet from my smart hub 2 and using the check signal, within the app it says the speed is poor.  If I then go to the conncted devices part of the app it says my phone connection strength is excellent, which do I believe?
1 REPLY 1
Message 2 of 2
Re: BT App
If you want to check the speed of your broadband using something other than the BT app there are many different speed tester on the Internet such as the following one.
Speedtest by Ookla - The Global Broadband Speed Test
