Message 1 of 7
BT Cloud Sync Folder
I want to change the BT Cloud Sync folder to a different drive.
I have disabled BT Cloud sync, but the path in the box underneath is greyed out and won't let me change it.
Help please.
6 REPLIES 6
Message 2 of 7
Re: BT Cloud Sync Folder
Hi @Tony07 Have you followed the steps that are shown on page 36 of the Cloud user guide to change the folder location?
Neil
Message 3 of 7
I can't get that page?
Message 4 of 7
I can't open a BT Cloud dashboard that looks like the one in the User Guide?
Message 5 of 7
Hi @Tony07 I'll send you a private message so you can get in touch with your details and we'll ask the cloud team to help you with this.
Neil
Message 6 of 7
Thank you.
I have managed to sort it by reinstalling the Cloud software
Message 7 of 7
@Tony07 That's great, I'm glad you got sorted.
Neil
