Message 1 of 3
BT Cloud and Windows 11
I updated to Windows 11 and now cannot see my BT Cloud files, I downloaded the latest version 21 8 9 but it will not run it flashes on the screen then vanishes. I get the cloud saying trying to connect to BT servers
2 REPLIES 2
Message 2 of 3
Re: BT Cloud and Windows 11
@fangio1954   Well I am  running BT Cloud 21.8.9 on three Windows 11 machines --see this post.  I would try uninstalling it and then a reinstall. If that doesn't help, then I would suggest you contact the Cloud Help Desk.   There have been previous postings where users had "Trying to connect to BT Servers" but I don't know how they resolved it.  You could wait a while on the Forum for an answer--if you ever get one-- so get onto the Help Desk.  That's what they're there for!!
Message 3 of 3
Thx did as you suggested and it now functions.
