Message 1 of 4
BT Cloud download problems
Hi
ive spent the last two days trying to download my files from BT cloud.
im still no further along
ive downloaded the latest desktop app
followed all the advice:
constant error messages
trying to download to a portable hard drive as not enough room on my computer:
you have attempted to add a folder that is used as a sync folder D
Befpre continuing this action you must remove the existing sync D folder
 if I try and use a folder on my laptop another error message pops up.. cannot use this folder…
its knackered my portable hard drive which now says it has errors and needs fixing but nothing happens when I select repair
I went and bought another 1 tb hard drive yesterday and can’t get that to save anything either
 I’m losing my mind
 then one folder I have on the bt cloud is completely empty nothing there when it should have all the back ups and files and photos of my old laptop
 Ive removed and downloaded the BT desktop app dozens of times
 tried doing it on a different lap top And the same errors
Please can anybody help?  Deadline in a few days
i had no idea it would be this difficult
3 REPLIES 3
Message 2 of 4
Re: BT Cloud download problems
Hi @Linds4
Welcome to the community, we'll try and help you get this sorted.
Have you tried downloading directly through your internet browser on the BT Cloud website?
Chris
Message 3 of 4
Hello
when I go to my.bt.com it says
you have registered for BT Cloud on another account. Please switch accounts to access your cloud.
so I don’t know?
Message 4 of 4
OK, thanks for trying, @Linds4
It may be worth giving our Customer Care team a call, so they can check everything from our side and help you get everything downloaded.
Chris
