Message 1 of 4
BT Cloud v21.12.15 MacOS Monterey 12.5.1
Is there a known issue with BT cloud sync and MacOS? When enabled nothing shows in the local BT Cloud folder on my Mac.
3 REPLIES 3
Message 2 of 4
Re: BT Cloud v21.12.15 MacOS Monterey 12.5.1
Can a moderator point me in the right direction to get support? Many thanks.
Message 3 of 4
Hi @Kielty23, sorry you're having a problem with the sync on the Cloud when it is enabled.
I've sent you a Private Message so you can contact the Mod team and we'll get this raised to the Cloud team for you.
Cheers
John
Message 4 of 4
Thanks JohnC2, just sent you a PM
