Message 1 of 3
BT Cloud
Has anyone found a way to stop BT Cloud from syncing with selected folders/files/photos.  I don't want to continue using it - especially if it's going to be discontinued.  I've removed the app from my mobile phone and the desktop, but want to know if I need to do anything else to stop the application accessing my computer.  Does anyone know?  It'd have though BT would have a dedicated instruction for this process, but I can't find it.
Thanks.
A
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: BT Cloud
Message 3 of 3
Re: BT Cloud
Thank you, the links helped, but gosh it took a while to remove all the files that were syncing, but the Dashboard was the way to do it rather than on the app which is what I was trying to use.  Thanks again.
